RCU Forums - View Single Post - Battery Configurations
Old 03-15-2011 | 06:58 PM
klhoard's Avatar
klhoard
My Feedback: (10)
Default RE: Battery Configurations
I use an FMA PowerLab 8. You can charge 2 packs in parallel. When starting the charge, it asks you how many packs you have connected in parallel and will double the amperage to the packs.
The packs need to be close to the same level of discharge, but as long as they were used together on the same flight, that should be no problem.
If you have a large enough power supply, the FMA Powerlab will charge up to 9 batteries in parallel.
