RCU Forums - View Single Post - mCX lower blade problems
Old 03-16-2011 | 09:35 AM
acdii
Default RE: mCX lower blade problems
Not many parts to these, had it all apart in 2 minutes.  I swapped motors and tested it, not the motors, lower assembly that is sluggish, so I have it all apart now and going to clean the bearings out and see if that helps.  Did you know the small bearing fit in the swash bearing?
