Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 mCX lower blade problems >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 03-15-2011 | 07:05 PM
Default mCX lower blade problems
The lower blades seem to have more and more resistance, and Icant figure out why. Cleaned the bearings, lubed everything, still they get slower and slower to where I can no longer keep it ffrom turning even with full right rudder. What can I do?
Right from the start I noticed the uppers spun more freely than the lowers, and now they stop spinning almost immediately when power is cut.
Old 03-15-2011 | 08:14 PM
Default RE: mCX lower blade problems
Motor problem perhaps? Did you crash and perhaps the shaft is bent?
Old 03-16-2011 | 04:08 AM
Shaft is straight, it tracks well, it just has more resistance than it should. Maybe I need to flush out the bearings in a solvent and relube them.
Old 03-16-2011 | 09:35 AM
Not many parts to these, had it all apart in 2 minutes.  I swapped motors and tested it, not the motors, lower assembly that is sluggish, so I have it all apart now and going to clean the bearings out and see if that helps.  Did you know the small bearing fit in the swash bearing?
Old 03-16-2011 | 10:07 AM
Fixed, the bearings needed cleaning, Soaked them in some Testers airbrush reducer, and they cleaned right up. now I need far less trim than I did when I first started flying it.
