RE: Testing prototype sound card
Yes this will work with all the HL S&S electronic sets out there. The reving of the motor is dependant on the sound set design. On the V8 I allowed for this, and will do the same as I work my way through other sound sets. When you set your throttle stick at the original configuration, you set the on to be just slighty before the motors turns. This allows the rev up possibility. There is no hobby radio involved in this. You can get this effect with the sound card and the stock radio. However the sound card works equally as well with a hobby radio too.
Some minor ergonomic changes to the board design need to be made to make it easy to plug and play using HL 8 wire cables. Then it is ready for manufacture. Stay tuned.
