RE: Laser Cut Kits
I build with Elmer's wood glue and I run into the same thing. Some structures are easy to simply use wood glue instead of CA. But sometimes if a built up structure such as a wing was designed for CA it can be difficult to use wood glue, but not impossible. Just sit down and figure out the best way to use wood glue instead of CA and you'll be fine.
Ken</p>
