RE: So who races their Aftershock 8e???
Well removed the rear wing and cage today to play around with a new set up. Going to use a Ve8 wing mount on my custom tower. But ran into one problem.Had to order a front swaybar set for it to get the hold down piece. Why you ask, cause the rear cage also holds that in place. Will place it back on so i can play at the track tonight but will be switching over with more mods to come. Going to work on reducing the front and rear diffs for a lower cg, and also working on reducing the amount of plastic on the front upper and lower steering plate.
Got to love a shop that has all this in stock. Thank you Kurt for your online service. Makes having a Redcat Product a simple and easy task to get parts.
