ORIGINAL: GravityWorx
Hey all,
I have a DX7 that I am using with a Delta wing setup. I would like to know if you can program the elevator to react with the throtle. For example: At low speed I think I will require down elevator in order to maintain level flight. As the throtle is increased the elevator would compensate for the speed returning to normal to again maintain level flight. Am I dreaming or is this an actual capability of the Tx.
Erich
Have you tried setting up a Programmable Mix with Throttle as the Master and Elevator as the Slave?
