ORIGINAL: GravityWorx
No I have not. This is my first Tx and i have got the delta setup working fine. I did not want to mess with any other settings before first asking the experts..
I understand what you are suggesting, now what are the steps. I believe I want about 30 percent down elevator at lower throtle but how is this accomplished.
thanks
Erich
I do not have a DX7 in front of me. In most cases, you would pick a Programmable Mixer, Enable it, and choose the Master (Throttle) and Slave (Elevator) channels, and then play with the numbers until you get the correct response. If you run into problems, you can set the PM to Inhibit and it will no longer affect your setup.
