RCU Forums - View Single Post - Trim Scheme?
Thread: Trim Scheme?
Old 03-22-2011 | 07:07 PM
JollyPopper's Avatar
JollyPopper
Default RE: Trim Scheme?
Look in Tower Hobbies or Horizon Hobby or any of the large hobby sites and you can see hundreds of schemes. As far as which covering you should use, only you can answer that and only after you use them both enough to learn the differences. Most folks believe UltraCote is a little easier to use and requires a little less heat. MonoKote has a much larger selection of colors and the backing is a bit easier to deal with. You pays your money and you takes your chances.
