Trim Scheme?
Old 03-22-2011 | 06:10 PM
Default Trim Scheme?
Hey, I have a CarlGoldberg Sr. Cadet that I am recovering, and was wondering if anybody has any good suggestions about what trim scheme I should do! Pictures or links to pictures would be great. Also should I use Monokote or Ultracote.
Thanks!
Old 03-22-2011 | 07:07 PM
JollyPopper's Avatar
Default RE: Trim Scheme?
Look in Tower Hobbies or Horizon Hobby or any of the large hobby sites and you can see hundreds of schemes. As far as which covering you should use, only you can answer that and only after you use them both enough to learn the differences. Most folks believe UltraCote is a little easier to use and requires a little less heat. MonoKote has a much larger selection of colors and the backing is a bit easier to deal with. You pays your money and you takes your chances.
Old 03-23-2011 | 02:57 AM
the colors that show best in the air for me are pink, orange, green.....too bad those colors don't go well together unless you wanted to do a 70's peace, love, dope scheme
