RCU Forums - View Single Post - Flaperon setup on Hitec Aurora 9 2.4 Ghz
Old 03-23-2011 | 07:29 AM
armody's Avatar
armody
My Feedback: (10)
Default Flaperon setup on Hitec Aurora 9 2.4 Ghz
Hi y'all,
I'm trying to set up flaperon on my Strega 40 using Hitec Aurora 9 2.4GHz. I've set up the flaperon and assigned a left slider on it, both servos work but the move in the same direction while moving left slider up and down. Also when I move aileron stick, they are moving in the same direction.
For ailerons, I was going to use Y-harness on one channel. My mentor told me you need to use 2 channels for aileron separately and one should be for flaps and then you may use it as aileron as flaperon. The receiver I'm using is Hitec Optima 7 2.4GHz, my mentor does not know himself about setting up the flaperon. As I mentioned that the servos should move clockwise and counter clockwise for aileron. I'm really not sure how to set it up, or do I have to do the reversing.
Does anyone have any experience, and is it wise to use flaperon for any fast plane which does not have a provision of flap? Anyone's using flaperon and if yes, how to set it up on Aurora 9.
Thanks in advance.
Mody
