RCU Forums - View Single Post - Testing prototype sound card
Old 03-23-2011 | 08:17 PM
  #55
YHR's Avatar
YHR
Default RE: Testing prototype sound card
ORIGINAL: smokinbarracuda
Thanks for explaining YHR, will the card be compatible with the HL high intesnsity flash? I ask because I currently have the anti track recoil modelbau unit from welsh dragon installed with built in flash. I needed to keep the HL sound so that meant I couldn't just disable the track recoil by unplugging from the rx18, hence the atr unit. Now with your sound card if I'm not mistaken I won't need the HL sound along with the track recoil (by pressing the K button), therefore can I completely remove the K button functions, uninstall the atr unit and then install the high intensity flash with your sound card? Or does the HL high intensity flash work in conjunction with the K button?
Sorry, one more question, thanks for your patience! Before you power up the engine is there no power to the motors like the original HL setup or is that fully customisable? Do you still have to press the engine start button before you can use any functions?
Many thanks. Can't wait!
Sorry I have been away on business. I do not use the high intensity flash, and don't know exactly what triggers it. As far as I know it works off the K button, so you may still need to use it.
The are no provisions for firing the high intensity flash with this sound unit.
You still have to hit the start button to turn on the functions of the RX 18. You just unplug the speaker.
Dan
