RCU Forums - View Single Post - Rear diff slip? Doesn't go straight on power
Old 03-26-2011 | 05:55 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Rear diff slip? Doesn't go straight on power
ORIGINAL: proanti1
I once completely tore down a GT transmission because of this problem. Turned out of be a small peice of fishing line wrapped around the axle near the outer bearing. It spun free by hand, but I guess would tighten down under load and cause it to pull to the side.
I've ran into the same problem here and there with my Nitro rustler over the years and I chalked it up to the diff being the problem. The grease I was using wasnt viscous enough and would cause the diff to favor the one wheel. I've noticed my 3.3 Rusty likes to "walk" when in wheelie mode where it hops from one tire to the other.. I was going to cure that problem with longer suspension arms from a Jato. A buddy did this on his N.Rusty 3.3 - he used Jato driveshafts and Jato rear arms and he said it was a totally new beast. This could be something worth looking into.
