RCU Forums - View Single Post - Running an engine in reverse
Old 03-26-2011 | 07:02 AM
HighPlains
Default RE: Running an engine in reverse
If it is this type then rotating the housing 180 degrees I think it is will allow reverse running.
There are not too many engines built with a removable crank housing anymore. But for those that do have this, you only rotate the front end by 90 degrees counter clock-wise. The rotor has to be open as the piston is rising when the engine is turned in the direction it is going to run.
