What plane could this be?
I picked up a glass fuse and foam cores from a swap meet. The plane is a 60 size pattern plane with a pipe tunnel running inside the fuse below the wing.
It almost looks like an LA-1 but it is not. The vertical stab is not molded to the fuse but has to be foam built then glued to it.
I can not for the life of me think of the name of this plane. I will post pics tomorrow.
Thanks.Phil
