RCU Forums - View Single Post - Trex 600e
Thread: Trex 600e
Old 03-29-2011 | 07:05 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Trex 600e
What radio?
Futaba needs the throttle channel reversed.
Also make sure your throttle is at low with the throttle trim all the way down to arm the ESC, you can also extend the low throttle end point to see if the ESC arms, you may need to calibrate the ESC to your throttle channel
