RE: Monokote
Brian,
You can use Monkote Trim Solvent or Xylene to glue the seam together before you put it on the plane. Use a good surface to work on (glass works best) and let it dry over night.
Don't apply too much heat to the seam when you are covering. Try to heat around the seam, not directly on it. Good luck.
Paul
