RE: Configuring a Tank with DX6 and BR6000
plug in throttle channel 1 channel 2 rudder channel 3 gun elevation channel 4 turret rotation then you need to go into radio programming and set all the servo linits to max and all the funtions will work you will not need to set trims to max to fire cannon or mg just stick to top and gun fires stick to bottom mg fires
