 Configuring a Tank with DX6 and BR6000 >
Old 04-03-2011 | 04:36 PM
ksoc's Avatar
Default RE: Configuring a Tank with DX6 and BR6000
About the steering trim issue. Not clear if you adjusted the steering trim on the DMD itself?
It is next to the RESET button. Labeled RUDD. Next to it is the M.GUN adjustment.
The light are a function of having all the trims set in the correct position - don't remember the exact sequence off the top of my head. Little tougher on a digital radio.
Old 04-04-2011 | 06:06 AM
dlobmwm3's Avatar
Thanks Kevin. I will try the adjustment on the DMD tonight. I COMPLETELY forgot about this. Thanks.
Old 04-04-2011 | 04:53 PM
dlobmwm3's Avatar
ORIGINAL: ksoc
THAT WORKED KEVIN!!!!YOU ARE DA MAN!!!! Thank you for helping out everyone. Now, 2 more items. I need to move the guns to button/switches on my other post.
<br type="_moz" />
Old 04-04-2011 | 10:08 PM
ksoc's Avatar
Id got a DX6 and DX6i. Got the Main gun to fire, but it has been a while so I don't recall exactly how. I DID reference the posts on RCU. One thing I do remember it is important where which direction some of the other switches are in, so if the switch you are working on isn't responding, try flipping some of the others. Will try to did out my radio and figure out what I did...... Once you figure it out remember to label write it down - unlike me
Good luck
