ORIGINAL: Jeff489
Flashing orange lights on the DMD indicate no control signal is incoming from the receiver. Specifically, the rudder channel. I'd suggest checking your bind between the radio and rx with a separate rx battery and servo. Remove the rx, rebind, and connect the battery to the battery terminal. Plug in the servo to 1 channel at a time and verify it works. Then, once you have it where you know it will run, add it back into the tank system and connect it to the DMD.
So you don't think its fried? I did have to reset my DX6 based on the suggestion by HondoBob. You think that reset my binding to the BR6000?
