RCU Forums - View Single Post - Configuring a Tank with DX6 and BR6000
Old 04-01-2011 | 03:11 PM
HondoBob's Avatar
HondoBob
Default RE: Configuring a Tank with DX6 and BR6000
ORIGINAL: dlobmwm3
ORIGINAL: Jeff489
Flashing orange lights on the DMD indicate no control signal is incoming from the receiver. Specifically, the rudder channel. I'd suggest checking your bind between the radio and rx with a separate rx battery and servo. Remove the rx, rebind, and connect the battery to the battery terminal. Plug in the servo to 1 channel at a time and verify it works. Then, once you have it where you know it will run, add it back into the tank system and connect it to the DMD.
So you don't think its fried? I did have to reset my DX6 based on the suggestion by HondoBob. You think that reset my binding to the BR6000?
I've had occasional hiccups with my DX6 which required resetting the transmitter, and binding to the receiver again is a good practice. Though I happened to have the bad luck of getting a malfunctioning receiver one time, the BR6000's have a well earned reputationfor excellent quality. Once your DX6 is reset and bound once again to the receiver it seems the final challenge would be properly setting the DMD to your preferred controls. In my case I like to set the left stick to thrust (ch1) and rudder (ch2), while my right stick is set to elevation/flaps (ch3) and aileron (ch4). In other words, I drive/turn with the left stick and point/shoot with the right stick.
