RCU Forums - View Single Post - kit cutting 101
Old 04-02-2011 | 04:29 AM
Free Bird
Default RE: kit cutting 101
When everything is cut out I go to the sander and sand everything to the inside of the lines.
Gray Beard - When you are sanding the parts to shape, shouldn't you sand just to the outside line? That's what I've always done. If you sand to the inside of the pattern line, wouldn't you be making the part on the line side? If the line is say 1/16" all the way around, when you're done sanding, wouldn't the part be 1/8" smaller overall?
FB
