RE: Gluing Techniques
Dip.
You need to use the right hardener for the application. Inever use anything faster than a 30 minute epoxy. Ihave done plywood boats with epoxy &glass or just epoxy over the plywood with roller or foam brush and it self levels - IF it has enough work time in the hardener. You can also thin it with acetone or alcohol if you need it thinner for brushing.
