RCU Forums - View Single Post - Hope for Scale Props for SPs
Old 04-09-2011 | 07:32 PM
Joe Lott
Default RE: Hope for Scale Props for SPs
Andi,
I just bought the VarioProp 16D 3-blade hub with 18.6" round tip blades for my TF Corsair. I used a slightly different method of marrying the hub to my 120SP. I designed a spacer to fit behind the hub, with a 12mm dia. flange to fit into the back of the hub. The setup works great. I set the pitch at 12" and ground tested it today. The 120SP turns the prop at 4660 rpm. As with your hub, mine got pretty hot but the blades were fine. I believe we've found a winner here and this hub looks great!
ID:	1591655   Click image for larger version
ID:	1591656   Click image for larger version
