RCU Forums - View Single Post - Wild Hare Electrics
Old 04-10-2011 | 06:38 AM
  #201
rctom's Avatar
rctom
Default RE: Wild Hare Electrics
My advice for IMAC type flight was to set it up so that the throws you plan to use are achieved at full servo travel. IF you only need 12 degrees of elevator travel, set it up so that full throw on the servo at high rates gives you 12 degrees. Anything else is wasted.
This gives you maximum servo resolution.
TF
