RCU Forums - View Single Post - fadec error problem
Old 04-11-2011 | 07:30 AM
AndyAndrews's Avatar
AndyAndrews
Default RE: fadec error problem
Check to make sure that the throttle cable is not backwards -
- next re-learn the TX. Make sure you are pushing the + button instead of the Up arrow when learning. If you don't press the + button the unit WILL NOT retain the settings when you go to the next step.
Andy
