fadec error problem
CA
xicoy fadec error on display, rc signal lost/ incorrect does this mean I need to relearn rc? it was working fine but i relocated the unit so i could get to it easier. also in the wording of instalation reads keep all connections well isolated between them refering to the pump and battery connectons. does that mean keep the battery cables away from the pump cabeles and buy how much thanks
Arden
Arden
Check to make sure that the throttle cable is not backwards -
- next re-learn the TX. Make sure you are pushing the + button instead of the Up arrow when learning. If you don't press the + button the unit WILL NOT retain the settings when you go to the next step.
Andy
Andy
Almost sure the throttle cable is reverse to the ECU, follow the color code or you could press the up arrow button to show the receiver voltage or move your throttle stick and watch the top right side % number.
