RCU Forums - View Single Post - Need Notes on Tiporare
Old 04-12-2011 | 05:06 AM
doxilia's Avatar
doxilia
Default RE: Need Notes on Tiporare
Joshua,
the DEPS setup from Central is designed to be supported along its length down the fuse. A little ingenuity could get you the support needed by running square CF rods from the wing TE are in the fuse to the tail post. The DEPS would then run alongside these rods. Getting lateral support between the glass fuse sides might be a little trickier but again with patience something could be done. It might be more trouble than its worth and using a round CF tube or glass arrow shaft with forked pushrods at the elevators might be the easier and classic approch to the elevators.
The Skybolt is a beautiful bipe.
David.
