RCU Forums - View Single Post - Sickle (V-2)
Thread: Sickle (V-2)
Old 04-12-2011 | 06:13 AM
  #129
cmoulder
Default RE: Sickle (V-2)
ORIGINAL: burtona
Question for other Sickle builders. Did you use any stab attachment other than the set screws in the incidence adjusters to hold the stab in place. I was thinking I should drill a couple of holes through the bottom of the stab into the tube and lock in place with small screws. No instruction on this (or anything else for that matter) were included.
If you run your fingers over the bottom of the stabs in the area where the stab tube runs, you will find some pre-drilled holes. I used some socket-head servo screws that screw into the stab tube, which has some wood plugs in the ends for this purpose.
