RE: Sickle (V-2)
I'm heading out to the field now for the maiden.
My AUW with f3aunlimited packs is 4853g. The weight without packs is 3656g.
APC 20.5X14 prop
carbon fiber spinner
(2 )36" extension cables (I'm using all pwr & signal wires)
AeroTech dual battery reg with switch
Castle HV85
Panel mount arming plug (12AWG wire)
Series Battery Connection cable 12AWG (Ties (2) 5s in series, I need this because I use the Celpro PL8 charger)
(2) 480mah receiver packs
1/8" plywood nose ring motor mount
I chose not to use any carbon fiber sheets for servo tray, battery tray or nose ring motor mount.
Glen
