ORIGINAL: JoshuaDA10
I appreciate the view on the DEPS, I will see when I get to that point and I may just engineer something myself. I like the idea of an arrow shaft, and it is classic. Would I be correct in my thinking that a side mounted elevator servo would eliminate the differential??
Josh,
The photo below should answer your question - in short, yes. I posted some pics higher up with some details of gear installation. By the way, the servo required to install in a side mounted fashion has to be of the low profile type in order for it to fit. I'm using a 1" Futaba. They're not cheap but then again, elevator is not something you want to do without...
Here's one to all of you who may be looking to thin out your engine collection. As I said I have an OS RE engine, and I am considering using it in the Tipo. Well, that was before I came across Carolina Custom Aircraft selling the T2A MkII which really needs an RE. My point is, if anyone as a Webra or a YS 2 stroke that they don't mind getting rid of and one which will go to someone who truly appreciates it let me know.
Josh
In case you don't hear form anyone, SE 61's are not in short supply on buybay or in the sales area of RCU. Both Webra's and YS's can be found.
David.
