RCU Forums - View Single Post - Super Skybolt Build
Old 04-16-2011 | 09:35 AM
  #202
Zor
Banned
Default RE: Super Skybolt Build
__Sabogh
You are right...[sm=red_smile.gif] I am glad that i did not put the kit away, but built it instead.
I have just made some changes to the wires holding the wing to the fuse.I did have some trouble getting the wing on when I was at the flying field, it was not easy to guide both wires into the small tubes in the wing at the same time.. I just shortened the rear wire with 2 milimeter, hopefully this will make it easier to slide the wing back in place.
Shortening the rear cabane wire was a good idea allowing inserting the front wire a bit into the brass tube and then concentrating on the rear one.
I tapered the end of those wires for a length of about 3/16" at their ends and rounded off the very tip.
In my kitthese cabane wires were not bent at the proper angles and I had to do some work on that. I also hardened up the surfaces of the guiding structure that lines up the wires to their brass tubes.
It is all part of "fit" before gluing. The original shape of the cabane wires were giving me plus one degree of decalage to the bottom wing instead of minus one degree. I had to make modificatons inside the fuselage to get the proper decalage called for in the drawings.
All a lot of fun and the satisfaction of doing things correctly.
Some of those kits are still sitting on someone's shelves and the above may help future builders.
I hope ___
Zor
Edited 18 April 2011 at 21:45 UTC to correct two typing errors .
