RCU Forums - View Single Post - Gp Dr1 Triplane
Thread: Gp Dr1 Triplane
Old 05-22-2003 | 04:10 PM
  #52
dmyers0403
My Feedback: (48)
Default First Real Flight of DR-1
First attempt was with a 58cc 4Cy engine !! Wrong idea, would not get off ground, when it did the wind over came it and tossed it to ground.
BUT - I replace small 4c with a OS61fx and what a difference !! First real flying was last night 5/21/03
Plane is absolutely a beautiful flyer. The added power got the tail up quickly which allowed the rudder to give plenty of control. Plane breaks ground easily with a very smooth fly-out. Flys very well with ailerons only, but rudder input or coupling makes it great (I do not couple rudder during take-off). Will roll and turn like crazy - lots of fun. This plane has only a slight climb when full power is added - not an issue. Very solid and holds a good heading. I did set the wheel wing at zero incidence to match wings and horiz. stab.
Only one click of left aileron trim was added, thats all.
I would not use anything less than a 91FS or 60 2 stroke on this plane. It needs the power to overcome drag, I do not need the power once it is up unless I want long loops. climbs etc.
Landing is really neat, the plane has a fast sink rate which I like, with a touch of throttle it stretches out for perfect wheel landings or three pointers.
Plane is not for beginners because it does require proper use of throttle and rudder. But for the more experienced flyer it is great.
I originally added a battery box for balance under cowl for the smaller engine. It is a little nose heavy for the OS61 but flys great.
