RCU Forums - View Single Post - To Deans or Not To, that is the Question
Old 04-17-2011 | 05:17 PM
WhiteWolf McBride
Default RE: To Deans or Not To, that is the Question
Guys...
Most heat shrink tubing will shrink with heat from a hair dryer. It takes longer, but heck, it beats using an industrial gun and melting wire-insulation, or using the iron and accidentially touching the shrink or wires, and ending up with a hole in it somewhere.
And when in doubt, try it on a bit of scrap. And you can always slip a piece of cardboard behind whatever ya wanna shrink to act as a heat-deflector, to protect other wires. If you're doing a lot, you could even make a small box-like unit (similar to a paint-box) to contain the area to be shrunk...
Me, I make carry-straps & tie-downs from shoe-laces, but the damned nylon was melting as the shrink was activating. Answer: used a cheap Zellers Hair Dryer ($10) If your SO is gonna toss the old one out, or you 'accidentially' drop/damage it, you can always get her a new one ... *grin*
WhiteWolf
