RCU Forums - View Single Post - To Deans or Not To, that is the Question
Old 04-18-2011 | 04:56 AM
shenlonco's Avatar
shenlonco
Default RE: To Deans or Not To, that is the Question
ORIGINAL: Shabbernigdo
nothin in my tank draws enough amperage to really warrent the change to deans. The stock connectors never even get warm.
Yes they may not but you will aways need to use a tiny screw driver to bend the connectors metal parts to make them fit tight as with the cheap tamiya connectors when you use them they lose contact due to the spreading of the metal contacts (poor desighn)... even battery chargers with the male end you always have to do what i said above because you will get false peaks from your charger if you don't always readjust the plugs contacts.
