RCU Forums - View Single Post - The most common problem with air systems in jets?
Old 04-22-2011 | 08:51 PM
sidgates
Default RE: The most common problem with air systems in jets?
I second Tim's comments about not using a knife to remove old air line. My preferred way is to "score" the tubing with a hot soldering iron pointed tip, then the line practically falls off and no scratch marks on the nipples. Scratches will leak.
