RCU Forums - View Single Post - The most common problem with air systems in jets?
Old 04-22-2011 | 09:38 PM
RCUser012
Guest
My Feedback: (73)
Default RE: The most common problem with air systems in jets?
a possible problem is trunnion blocks getting stuck in lock position ... if necessary, make sure you file the frames / blocks so they can't get stuck locked .. this depends on retract design / geometry often times ...
~V~
