ORIGINAL: MinnFlyer
As others have said, rotate the prop backward against the compression before applying the starter.
I use a jump starter for car batteries. It works great and you can keep it in the trunk in case you ever need to jump a car battery
http://www.sears.com/shc/s/p_10153_1...=1303556541603
Used mine twice now for jump starting cars out at the field.
