RCU Forums - View Single Post - 3W/DA Ignition timing
Old 08-12-2003 | 05:10 PM
BrianB
Default 3W/DA Ignition timing
Anyone have a simple method for setting the timing on these ignitions, my Ch Ignition is easy as it will fire while turning over slowly by hand, just used a degree wheel and set it. The 3W/DA ignitions have to spin over fast to get the fire and would need the timing set while running. Can you time with the opening or closeing of the hall sensor. I tried rigging steel tubing from plug cap to plug and clamping inductive light to it but engine won't start this way { not enough spark ???}. Enigine is a 3W70.
Thanks, Brian
