3W/DA Ignition timing
Old 08-12-2003 | 05:10 PM
Default 3W/DA Ignition timing
Anyone have a simple method for setting the timing on these ignitions, my Ch Ignition is easy as it will fire while turning over slowly by hand, just used a degree wheel and set it. The 3W/DA ignitions have to spin over fast to get the fire and would need the timing set while running. Can you time with the opening or closeing of the hall sensor. I tried rigging steel tubing from plug cap to plug and clamping inductive light to it but engine won't start this way { not enough spark ???}. Enigine is a 3W70.
Thanks, Brian
Old 08-12-2003 | 10:23 PM
Banned
Brian, best bet is to just bolt the pickup down onto the motor witht he screws about halfway along the adjustment slots, run it and see how you like it. If it seems boggy, advance the timing to the max amount possible and leave it alone after that.
The DA and 3W ignitions use an inductive coil pickup, that uses the passing magnet to generate an electrical "spike". The faster the magnet passes the coil, the sooner the "spike" occurs, and the more ignition advance you get. About the most "advance" you can get out of a design like this is in the neighborhood of 15-18 degrees, usually, simply because of the inherent limitations of the design. At idle, and "base" timing, you actually have about 10-15 degrees of advance and this increases to a maximum of about 25 degrees or so (depending on engine speed). This is perfectly adequate for most engines, and very little advantage will be found by going for more advance.
Your 3W had the magnet aligned to the pickup coil from the factory and the DA ignitions pickup is basically the same design. I'd put the ignition pickup directly over where the 3w pickup used to be, and leave it at that. I doubt you will get more power or performance by playing with the timing a lot, or by advancing it outside the range already set into the pickup coil assembly.
Hope this helps
Old 08-12-2003 | 10:33 PM
The factory setting for the sensor is as follows. Set the engine to TDC by aligning the marks on the hub and case. Loosen the screws on the sensor and move it so the center of the magnet is right between the "3" and "W" embossed on the pickup sensor. It's easier to see if it's aligned if you draw a line with a felt tip marker through the center of the magnet first. Then the line will stick out from under the sensor and can be easily seen.
Old 08-13-2003 | 11:00 AM
Default Thanks
Chris and Diablo. I will check it but it sounds like it is on the money already.
