RCU Forums - View Single Post - SIG Aerobipe build
Old 04-28-2011 | 11:25 AM
aerowoof
Default RE: SIG Aerobipe build
didn't do them as they were not required for flight.if I remember there were small tubes epoxied to the ribs that wire on the ends of the struts plugged into.I used an os max 15 back then .do not try to add airlerons as it won't turn with them.found out the hard way.while it will bank and roll will not turn without using rudder.
