RCU Forums - View Single Post - SIG Aerobipe build
Old 04-28-2011 | 01:24 PM
Scirocco14's Avatar
Scirocco14
Default RE: SIG Aerobipe build
ORIGINAL: aerowoof
didn't do them as they were not required for flight.if I remember there were small tubes epoxied to the ribs that wire on the ends of the struts plugged into.I used an os max 15 back then .do not try to add airlerons as it won't turn with them.found out the hard way.while it will bank and roll will not turn without using rudder.
Thanks, Aerowoof. I'll try to come up with something regarding the interplane struts. Maybe a scaled down version of what's used on a Goldberg Ultimate or SIG Liberty Sport.
Good to know about the ailerons. I pondered them for a while, and then figured I'd have to take the dihedral out...and then wondered how much to leave in...decided I didn't feel like redesigning the plane. So stock it'll be!
Thanks again,
Mark
