RCU Forums - View Single Post - GP Waco?
Thread: GP Waco?
Old 04-28-2011 | 07:48 PM
  #560
Tony V.
Default RE: GP Waco?
ORIGINAL: AncientCityFlyer
Well, if the weather holds I plan on doing the maiden on Sat am. Forcast looks good. Mine balanced right on the spot and came in 12.75 lbs. I've added a few exra touches in the final finishing. Had some extra ''Cub Yellow'' & Black covering sitting around so I coverd the upper wing joints. They were very tight to begin with but I thought it really made it look like single wing. Also placed my fuel dot and access hole for adjusting the carb on the right side of the fuse in the black scallop. Hard to spot unless you're up close. Also added some cockpit coaming to the aft cockpit. Will do the same for the forward cockpit later. I just want to get this sweety in the air.
The full scale had a 3 piece wing the joints show.
