RE: Earthquake 3.5 barely accelerates
Appreciate your help but i have no idea what you mean =/ The dogbones are the driveshafts right? If i spin the spur gear all 4 wheels spin, so i doubt its that!! But that nut you were talking about, with the spring, that wasnt tightened properly, you think that could be causing the problem?? Thanks
Edit: Does the clutch look OK btw???
