RCU Forums - View Single Post - MVVS ignition problem.
Old 05-03-2011 | 01:44 PM
apalsson's Avatar
apalsson
Default RE: MVVS ignition problem.
The 26cc (later versions) come with the ICU-L ignition.
The battery test is a jumper that is plugged into the jumper block on the side.
Try downloading the manual from www.mvvs.cz - you will see from there which ignition you have
