RCU Forums - View Single Post - Plane Cleaner
Old 05-05-2011 | 06:37 AM
tony0707
Default RE: Plane Cleaner
HI
AFTER 20 YEARS of using windex on film coveringfound out it is not a good idea -as it will lift and open the seamsa coating of clear dope on the seams and decals will stop thatyou will not see the clear dope after it drys
before i put film on an air frame-i will coat the balsa with clear dope in any spots i know will collect the burnt fuels oila good example is the aileron seam on the exhaust side of the airframe (only applys to glo fuel )
i use silicone on my wing seat to prevent fuel and air from getting into the airframeair creates dragall my fuses are sealed as much as is possible to the outside
ENJOY BEST REGARDS TONY
