RCU Forums - View Single Post - servo mounting
Old 05-08-2011 | 06:58 AM
dredhea
My Feedback: (13)
Default RE: servo mounting
ORIGINAL: rye
hi
you could use some 1/8 plywood and double it where the screws come though the servo holes, goodluck rye
This will work well. Remember to harden the screw holes with thin CA. Drill your pilot hole, install the screw to make threads in the wood, then remove it. Add a few drops of CA in the hole. This will make the threads hard and less likely to strip out.
