RE: water proof
You can allso take the RX out of the case and dunk it in Corrosion X pat dry put back in the case, RX is now waterproof for the season. If you do dunk the plane the RX will still work. Just open up the RX at the end of your float fly session and let it dry out, your good to go till the next float fly.
