RCU Forums - View Single Post - Height difference with change to CM-6 plug??
Old 05-11-2011 | 06:39 PM
av8tor1977's Avatar
av8tor1977
Default RE: Height difference with change to CM-6 plug??
That's a good idea. Thanks to you as well Jody!
Note to anyone else trying this: Be sure you get a good soldered connection to the shielding, and a good ground connection to the engine. If not, you'll blow your sensor..... (I've had it happen when my ground failed on the CH systems.)
AV8TOR
