Thomas, that's too bad you sold the UV. It should fit with the wings on in my Santa-Fe
It is possible i might have to cut-off a piece of the trailing edge on the rudder. In that case I could use the same technique as you did. What thickness of polyply did you use?
Cheers,
V.
